Problem for do UPgrade with PCD
gsilva
Hi all,
We need do a upgrade from CUCM 8.0 to 10.0
We are migratin with the Prime Collaboration Deployment, but when we add the Esxi host, an error appear.
"Failed to mount Cisco Prime Collaboration Deployments export as NFS store to the ESXi Host"
The UCS is a UCS 240.
We can discover the cluster old, but don´t cant add the Esxi host.
We deploy the new VM for the new CUCM 10.0
Please, I need your help.
Guillermo
Jaime Valencia
duplicate
https://supportforums.cisco.com/discussion/12207236/error-do-upgrade-prime-collaboration-deployment
java
if this helps, please rate
