02-08-2017 06:00 AM - edited 03-19-2019 12:06 PM
Going to upgrade UC from 11.0 to 11.5 SU2 - latest release. Just want to make sure i'm reading the documentation correctly. Do I need to install any COP files? Maybe ciscocm.cuc_11.5SU1_pre_upgrade.cop.sgn ?
I'm planning on just going into OS administration on PUB/SUB one at a time and just going to the install/upgrade menu item and upgrade from there. Anyone have a better way? I'll be doing a CUCM/CUP upgrade at the same time via PCD. Can PCD upgrade UC too?
Thanks for your time.
02-08-2017 08:22 AM
No, that COP only needs to be used when going to SU1, SU2 (and any new SUs) do not require that particular COP file.
The upgrade procedure is covered in the upgrade guides for the product, you can find the necessary steps there.
The PCD documentation has a table in which it explains which PCD tasks are compatible with the UC apps, and the versions. Have you reviewed that table?
05-13-2018 04:46 AM
Nice one - thanks for the clarification Jamie. I had the very same question.
Richard
