Community Member
Upgrade Order 9.x to 10.5
We're currently running the below UC applications and I'm trying to determine the best order for migration:
CUCM 9.1.2
CUC 9.1.2
CUAC Enterprise 9.1.1
Does the Attendant Console have to be migrated first? Is anyone running the CUAC 9.x in a 10.x environment? If possible we would like to hold off on upgrading that component until later, but not sure if it's possible.
2 ACCEPTED SOLUTIONS
Yes, no AC on 9.x is
Yes, no AC on 9.x is compatible with 10.x CUCM, but 10.X ACs are compatible with 9.x CUCM.
It would be AC -> CUCM -> CUC
java
if this helps, please rate
www.cisco.com/go/pdi
CUC is pretty much a wildcard
CUC is pretty much a wildcard, you can upgrade it at anytime and still keep CUCM compatibility.
java
java
Community Member
Thank you Jaime, that's what
Thank you Jaime, that's what I figured, but was hoping I could do it last. Also, just to confirm, the CUCM and CUC can be done in either order, correct?
java
Community Member
Thanks again..
Thanks again..
155
