Community Member
User Facing Features and Upgrades from 6.x and 7.x (MWI, DND, CFA, ...)
The 9.1.1 upgrade guide states:
"For upgrades from Cisco Unified Communications Manager Release 8.x, changes that are made to the following user-facing features get preserved after the upgrade completes ...".
What happens to user facing features like MWI and CFA for upgrades from 6.x and 7.x?
1 ACCEPTED SOLUTION
Purple
Hi,you can refer the link
you can refer the link which says
User Provisioning
For upgrades from Cisco Unified Communications Manager Release 4.x and 5.x, any provisioning that the end user performs to user-facing features after the upgrade begins could get lost.
For upgrades from Cisco Unified Communications Manager Release 6.x, changes that are made to the following user-facing features get preserved after the upgrade completes:
Call Forward All (CFA)
Message Waiting Indication (MWI)
Privacy Enable/Disable
Do Not Disturb Enable/Disable (DND)
Extension Mobility Login (EM)
Hunt Group Logout
Device Mobility
CTI CAPF status for end users and application users
Credential hacking and authentication
Recording enabling
Single Number Reach enabling
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/cucos/7_1_2/cucos/osg_712_cm/iptpch7.html
regds,
aman
1 REPLY
Purple
User Provisioning
Hunt Group Logout
Device Mobility
Recording enabling
regds,
aman
151
