07-07-2017 02:00 AM - edited 03-19-2019 12:36 PM
Hi Folks,
I am planning to upgrade my unity connection server from 9.1.1 to 10.5.2. We have two servers in active/active mode.
The servers are on UCS B-series (Model:5108), I could not able to find virtualization matrix for the same.
The current user strength is around 400 and we need Unified messaging facility.
Please help me with the hardware requirement for the same.
Currently the hardware specification is
Processor: 1 vCPU
Memory : 4096 Mbytes
Number of Disks : 1
Hard Disk #1
Size (in GB) : 160
Please help.
07-07-2017 06:08 AM
Here you go:
http://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/uc_system/virtualization/virtualization-cisco-unity-connection.html
07-07-2017 06:41 AM
Thanks for the response Chris.
This is Virtualization for Cisco Unity Connection (CUC) doesn't have details about B-series UCS.
Secondly, if i want to match it with this matrix to which model should i match, we are using UCS B200(5108).
07-07-2017 06:55 AM
Sure it does, if you click on the links under "L_TRCs" or "Click here to download support of non-orderable servers" for example it will redirect it to page listing hardware falling under that category.
07-07-2017 12:06 PM
Hi Chris
+5 to you.
Please also help me if i need to perform any particular step while upgrading it.
Thanks again!!
07-07-2017 12:15 PM
Thank you, but it appears you did not rate the post :-)
Review the Application upgrade guide which will point out any additional items you need to worry about.
