DSP calculator - 3825 Voice Gateway
ctd_77801
I have numerous solutions for clients built out with a 3825 Voice Gateway using 4 - 2MFT VWIC cards to terminate 8 PRIs.
I was recently using the Cisco DSP calculator and tried building this to verify I had the propor number of DSP modules.
I received an error stating that this configuration was unsupported because I couldn't put enough DSPs on the motherboard for the number of voice calls I would process.  This was even with the G.711 codec.
So can I not terminate 8 PRI's on VWICs with the 3825 or am I using the calculator wrong?
I know when I add the Network Modules they have their own onboard DSPs, which I believe don't have any effect on the onboard need for DSPs.
skilambi
I just tried this configuration and I have no issues. The output is 3 PVDM2-64 all on the mother board. I suggest you use this calculator
http://www.cisco.com/web/applicat/dsprecal/tdm_services.html
Of course ISR G2 give more bang for the buck with PVDM3 so definitely keep that in mind for the future
Srini
