10-11-2011 07:42 PM - edited 03-19-2019 03:46 AM
Hi All,
Just wondering if it is possible to use the CUPC client to collect voicemail from a CUE server.
We have CUCM, CU, and CUPS here in the enterprise environment, but one of our branch offices has their own Cisco Unity Express router.
We are in the process of rolling out the CUPS client and I was wondering if the users at the branch office would be able to collect their voicemail using the CUPC client?
thanks very much for any info
regards
amanda
Solved! Go to Solution.
10-12-2011 06:54 AM
No, they're not compatible
Table 4 Cisco Unified Personal Communicator Server Requirements
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
10-12-2011 06:54 AM
java
