1040 Sensor makes flap in both 3560 Switch Interface
Hi Everyone,
Last night I put a 1040 Sensor in a 3560 Switch (c3560-ipbasek9-mz.122-37.SE.bin)and both of the interfaces started to flap (4 min intervals)
I read one tip envolving Switch 3550 using the following command
power inline
delay shutdown 20 initial 30
but this command isn't available in 3560
Any tip or help ?
Thanks in Advanced
Andre Lomonaco
1 REPLY
Re: 1040 Sensor makes flap in both 3560 Switch Interface
Is your sensor receiving an IP address from your dhcp server?
If not, try configuring the port where the sensor is connected with switchport access vlan voicevlannumber
instead of using switchport voice vlan number
This worked for me. Port is no longer flapping and the sensor get's an IP address.
Rgds,
Jeroen
119
