4.0(5) AvCs Error - AvDalDbDirectory.cpp exception and handled
Anyone see this before with unity 4.0(5) and have any ideas on cause? From hex value looks like maybe a permissions issue. First time I've seen this error on this unity server thats been in place awhile.
Event Type: Error
Event Source: CiscoUnity_AvCs
Event Category: None
Event ID: 100
Date: 8/24/2006
Time: 4:46:19 PM
User: N/A
Computer: UNITY
Description:
Exception occurred and handled. File: e:\Views\cs_CU4.0.4.221\un_Doh1\Dal\DalDb\AvDalDbDirectory.cpp at Line: 685 - Error: 80004005H Call stack:
0x5F012F8D AvDalDbSvr.dll: <unknown symbol>
Green
Re: 4.0(5) AvCs Error - AvDalDbDirectory.cpp exception and handl
Could you please the GUSI,
How ofter you get this error?
During an import or AD synch?
Any changes in Permissions or Group Policies that may affect,
Double check AVDSAD and AVDSGC are using the proper account- and have the proper permissions. (You may try re-running PW)
If that doesnt help then we will need to enable the Directory Monitor Traces in the Unity Diagnostic Tool and reproduce the issue
to give you a better response and root cause.
This is first time this error occured to my knowledge and the app log goes back quite a bit, and this was first occurance of this error. It happened 8 times all at the same time back to back then no more of them.
No one was making any changes or doing anything in AD at the time from what I have gathered so far.
Since this is first time I've seen this error and it hasn't happened before on this server, I was mainly interested in seeing if others have seen this or not, what they did/found, etc before really digging into it.
Will check into these things and post back later.
Thanks.
Bronze
I am on 4.2 but same thing happen to me. The other difference is that I got this first error which required a Unity physical restart and a week later got your error
Event Type: Error
Event Source: CiscoUnity_Doh
Event Category: Error
Event ID: 32013
Date: 2007/10/13
Time: 01:25:31
User: N/A
Computer: CA1UNITY1
Description:
Doh logon failed due to messaging component logon error: 80040200H
Notes: All Cisco Unity Errors
Event Type: Error
Event Category:
Event ID: 100
Date: 2007/10/19
Time: 18:44:47
User: N/A
Computer: CA1UNITY1
Description:
Exception occurred and handled. File: E:\Views\CU4.2.0.110\un_Doh1\Dal\DalDb\AvDalDbDirectory.cpp at Line: 685 - Error: 80004005H Call stack:
So far everything works so will also go on monitoring state and check on things out later.
167
