6921 Will not save on phone correctly
I am trying to change the ringtone on some 6921 phones from the default ringtone. When I select a new one and select save, it states it saved and then displays "unknown error" and does not update. How do I figure out what the issue is as I can play the tone before I save it, so I know it is loaded.
Everyone's tags (2)
1 REPLY
Hi James,
Sounds like it could be related to the following bug: CSCtk06960 CME: ALL-LANG: 69xx: Unknown Error is displayed in ring tone settings.
Try upgrading the firmware on the phone and see if it fixes the issue.
HTH,
Chris
503
作成コンテンツを作成するには してください
