7906 not found in call manger 4.1(3)
7906 phone is found in the call manager 4.1(3).Do i need to upgrade to some service reale for example sr5 as that is the latest one.
Hall of Fame Super Red
Re: 7906 not found in call manger 4.1(3)
Hi Ganesh,
You are right on track here. The 7906G requires at leat 4.1(3)SR3a. It's always a good idea to roll the new SR's when possible anyways, so this is probably a good fit.
Cisco Unified IP Phone 7906G Requires Cisco Unified CallManager release 5.0(3) or later; 4.2(1)SR1 or later; 4.1(3)SR3a or later; or 3.3(5)SR2 or later.
From this good doc;
http://www.cisco.com/en/US/products/hw/phones/ps379/prod_release_note09186a008068f542.html
Hope this helps!
Rob
Thanks the minimum release required is sr 3a but the latest is sr5a so can i directly install sr5a or is there a upgrade process involved in the service release.Thanks in advance.
the release notes says For this Service Release, Cisco supports upgrades from any Cisco Unified CallManager 4.1(3) release up to 4.1(3)ES106.Does this mean the service release can be installed on the 4.1(3) or does this require a an basic service release.
Hi Ganesh,
You should be good to go (straight to sr5a). I had a look through the Read-me and don't see any issues. This does fix a TON of bugs so take some time reading up on what has changed.
Hope this helps!
Rob
EDIT: The note about ES106 should not apply to you in this case.
thanks a lot
120
