Community Member
Add CUPC to UC 6 Device NameRequired Field problem
I'm getting the following error, if I try to add a CUPC
Update failed. [491] TypeDbErrors.INVALID_PRODUCT_NAME
the name is only 8 chars long CUPCtest. Any other name also fails.
anyone had this problem before?
Thanks in advance
Community Member
Re: Add CUPC to UC 6 Device NameRequired Field problem
I found it,
the UPC Clients need to be named UPC
Community Member
In my opinion that is not correct. You should insert the
UPC. Be sure you insert the username in CAPITALS. otherwise it will not work
761
