After 3 ring a call auto disconnect.And get a message "resource unavailable
ccnarick
Topology: Phone(31295)----EricssonPBX-(PRI-E1/QSIG)--3725Router--(MGCP)-UC601----IP Phone(30801)
What may be the cause of resource unavailable, unspecified disconnect message ?
When I try to place a call towards PBX that is from 30801 to 31295. I receive this error after 3 rings.
I get the following debug output:
Router#
Apr 29 09:42:32.126: ISDN Se1/0:15 Q931: TX -> SETUP pd = 8 callref = 0x0002
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Facility i = 0x9FAA06800100820100A10D02010002010080053330383031
Calling Party Number i = 0x0181, '30801'
Plan:ISDN, Type:Unknown
Called Party Number i = 0x80, '31295'
Plan:Unknown, Type:Unknown
Apr 29 09:42:32.230: ISDN Se1/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x8002
Progress Ind i = 0x8181 - Call not end-to-end ISDN, may have in-band info
Apr 29 09:42:32.326: ISDN Se1/0:15 Q931: RX <- ALERTING pd = 8 callref = 0x8002
Progress Ind i = 0x8182 - Destination address is non-ISDN
Apr 29 09:42:44.363: ISDN Se1/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x0002
Cause i = 0x81AF - Resource unavailable, unspecified
Apr 29 09:42:44.419: ISDN Se1/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x8002
Apr 29 09:42:44.443: ISDN Se1/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x0002
Router#
5 Replies 5
gogasca
Level 10
Level 10
Failing for all calls? Or only this extension
Could you please attach CCM SDI detailed trace.
Codec in voip side for MGCP is G711 or G729?
Let us know
Yes,all h323 ip phones.
The codec is G711.
A call is placed at 2008/05/08 08:44 ~ 08:46
A call is placed at 05/08/2008 08:43 ~08:46
ccnarick
No body response ....
