Community Member
AIM-CUE module won't boot
Hi all,
I've bought an AIM-CUE to play around with Unity Express but I'm having some significant issues getting it going. When the module is booted it seems to constantly power cycle itself like so:
Initializing memory.  Please wait. ... 256 MB SDRAM detected
BIOS Version: Cisco SE-AIM 01.02
BIOS Build date: 08/14/03
System Now Booting ...[BOOT-ASM]
7
Please enter '***' to change boot configuration:  Filesystem type is reiserfs,
partition type 0x83
kf: a1 : (hd0,0)/bzImage root=/dev/hda1 ro plat=aim
kf: a2 : (hd0,0)/bzImage root=/dev/hda1 ro plat=aim
in grub_open: (hd0,0)/bzImage root=/dev/hda1 ro plat=aim
in grub_open1: /bzImage root=/dev/hda1 ro plat=aim
in grub_open2: /bzImage root=/dev/hda1 ro plat=aim
in grub_open3: /bzImage root=/dev/hda1 ro plat=aim 1
in grub_open4: /bzImage root=/dev/hda1 ro plat=aim
kernel_func: kt: 0
in boot func: kt: 0ÿ
However it then keeps repeating this and never (seems) to go any further. At first I thought it was just a corrupt software image so I tried to load up 7.2.1 (latest for this module) using boot helper and I'm able to get into the bootloader and make my configuration options:
Please enter '***' to change boot configuration: ***Probing...[EEPRO100]Found I
ntel EtherExpressPro100 82559ER at 0x00000000 ROM address 0x003FC000
Ethernet addr: 00:04:9A:49:3C:70
equalizer val: 16
ServicesEngine Bootloader Version : 1.0.17
ServicesEngine boot-loader>
but after issuing the boot helper and the AIM-CUE sucessfully downloading the image I then get this:
ServicesEngine boot-loader> boot helper
Probing...[EEPRO100]Found Intel EtherExpressPro100 82559ER at 0x00000000 ROM ad
dress 0x003FC000
equalizer val: 16
Me: 192.168.1.2, Server: 10.0.80.3, Gateway: 192.168.1.1
Loading cue-installer.aim.7.2.1
Dbg: Final image size: 11713916
Debug: bl_sz: 115296
reading key: 0
reading key: 1
reading key: 2
reading key: 3
reading key: 4
reading key: 5
in verifysignature_md5, MD5 hash generated now, str format:hexmd5:ba556d2ce37ea
f6f829259196cd40ea5
Verifying signature now...
calling RSA decrypt now
mem ptr: 0 704 832 968 1040 1172 1184 1196 1208 1220 1228 1244 1268 1284 1300 1
316 1332 1344 1360 1384 1400 1664 1804 2080 2224 2364 2880 3396 3660 3924 4188
RSA decrypt returned:-1
verifysignature_md5, Orig MD5 hash generated during encryption:¼zÌzi|T{¬Å¼²|
mem ptr: 0 704 832 968 1040 1172 1184 1196 1208 1220 1228 1240 1260 1276 1288 1
304 1320 1332 1348 1368 1380 1644 1784 2060 2204 2344 2860 3376 3640 3904 4168
signatures do not match...
Invalid signature !!ÿ
Unfortunately the module then goes back to restarting constantly. Just incase I was unlucky enough to get a faulty image I tried an older one and got the same results. I'm unfortunately at a bit of a loss on what to do next. Could it be a hardware issue?
Any ideas?
Everyone's tags (2)
1 REPLY
Hall of Fame Super Gold
Re: AIM-CUE module won't boot
Is that a 1-GB module ?
All requisites seems to be good. May be bad memory or faulty HW.
1242
