07-07-2009 01:55 PM - edited 03-18-2019 11:19 PM
Hello folks
we have CUCM 7.0 and we have attendant console deployed, is there a way to configure the parked calls so if no one retrieves that call when the call rings the original phone, have it display that it was a previous parked call ?
thanks
07-07-2009 04:36 PM
Hey Cris
Are you using the old AC?
Or one of the new CUxAC?
As far as i remember you should get something like a *XXXX with the * meaning it was parked (at least on old AC), i can check tomorrow. You should be getting also something on the phone, do you see any indication on the AC phone it was a parked call?
java
if this helps, please rate
07-08-2009 06:54 AM
I'm using AC the plug-in that was posted on CCO for CUCM 7.x
I was making some testing yesterday and there isn't any notification to let you know that the call was previously parked
