Community Member
Auto Attendant issue
i have configured auto attendant on uc520.internally its working fine and transfering calls to operator.but when i call on PSTN no. of auto attendant then i can hear the promts. but it is not accepting the keys. pressing 0 or 1 do nothing.prompt keeps on playing.any one can help? Thank You
Re: Auto Attendant issue
Make sure DTMF relay is configured under the dial-peers
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Community Member
this is my dial peers and i am using cisco configuration assistant
port 0/3/3
dial-peer voice 1000 voip
permission term
description ** Incoming call from SIP trunk (Generic SIP Trunk Provider) **
voice-class codec 1
voice-class sip dtmf-relay force rtp-nte
session protocol sipv2
session target sip-server
incoming called-number .%
dtmf-relay rtp-nte
ip qos dscp cs5 media
ip qos dscp cs4 signaling
no vad
dial-peer voice 1001 voip
corlist outgoing call-local
description ** star code to SIP trunk (Generic SIP Trunk Provider) **
destination-pattern *..
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1003 voip
description ** Passthrough Inbound Calls from CUE **
translation-profile incoming SIP_Passthrough
b2bua
session target ipv4:10.1.10.1
incoming called-number ABCDT
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 1005 voip
description ** Passthrough Inbound MWI from CUE **
b2bua
incoming called-number A80T
codec g711ulaw
no vad
dial-peer voice 1021 voip
corlist outgoing call-national
description **CCA*Generic Locale*all calls**
translation-profile outgoing OUTGOING_TRANSLATION_PROFILE
preference 1
destination-pattern 9[1-9].T
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1023 voip
translation-profile outgoing PSTN_Outgoing
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1024 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1025 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 3002 voip
description SIP
translation-profile incoming SIP_Called_6
voice-class codec 1
incoming called-number 2225248[1-9]
dtmf-relay rtp-nte
no vad
dial-peer voice 59 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 1002 voip
preference 1
voice-class codec 1
session target ipv4:10.200.200.243:5060
dtmf-relay rtp-nte
no vad
dial-peer voice 1020 voip
preference 2
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 2001 voip
description ** cue auto attendant number **
translation-profile outgoing PSTN_CallForwarding
destination-pattern 100
b2bua
voice-class sip outbound-proxy  ipv4:10.1.10.1
codec g711ulaw
no vad
dial-peer voice 2003 voip
description ** cue auto attendant PSTN number **
translation-profile outgoing AA_Profile
destination-pattern 22252480$
b2bua
codec g711ulaw
no vad
dial-peer voice 1006 voip
description ** AA from SIP Trunk (Auto Attendant 1)**
translation-profile incoming AA_Profile
voice-class codec 1
incoming called-number 22252480
dtmf-relay rtp-nte
no vad
Community Member
This is the config which works for me in CME-CUE VM & AA situation:
dial-peer voice 200 voip
description "Dial-peer for VM"
destination-pattern
dtmf-relay rtp-nte sip-notify
codec g711ulaw
no vad
dial-peer voice 201 voip
description "Dial-peer for AA"
destination-pattern
codec g711ulaw
no vad
Community Member
i have tried different dtnf-relay settings but it didn't
work. i am using sip trunk is there anythning to do from sip provider end?
650
