4 digit dialing from an Avaya system to a CUCM 8.6.2 server works fine, the Avaya is set as an h.323 gateway in CUCM.
Once the call is active if the Cisco phone places the Avaya caller on hold they hear no hold music and the call stays active until the Cisco phone tries to retrieve it. Then it's a fast busy on both end.
Are you using G711 or G729 for these calls? If using G729 the CUCM software MTP cannot be used as it only supports g711, you would have to use a gateway-based MTP.
Try setting the calls to G711 to see if it works as a test.
Aaron
Aaron
Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
IntroductionCUCM Routing RulesDial String implementation PolicyCUCM Routing LogicSIP URI Call Routing Analysis+++ Case Study: 1 ++++++ Case Study: 2 +++Conclusion
Introduction
Over the last few months, I have had the privilege of working on SI...
view more
Hi All,
Are you getting this error “Installer User Interface Mode Not Supported. The installer cannot run in this UI mode. To specify the interface mode, use the -i command-line option, followed by the UI mode identifier. The value UI mode identifiers...
view more
