It sounds like you are trying to do these updates via BAT?
Within the "insert user Device Profiles Configuration" window there is an "Override the existing configuration" tick box.
If you check this does it help?
I would personally create a .txt file if you are doing bulk updates to include all the EM profiles. Then you can add the service on to all the UDP's and upload it.
Please rate useful posts....
