Block DDI for extention
Hi Team
I configure a voice-dial-peer for DDI in the VOice Router and the Translation Patern in the CallManager
But the DID is workin for all the extention
I want block some extion to not receive the call
and
Re: Block DDI for extention
if you want to block a call based on ANI use H323. search in NetPro as this is a very common question. please search NetPro as someone most probably has asked the same
java
if this helps, please rate
java
www.cisco.com/go/pdi
I didnt find any similar case
I have a DID range 2602300 - 2602399
Ext Number 301 - to 399
Dial peer in Voice Gateawy
dial-peer voice 2300 voip
destination-pattern 26023..
session target ipv4:"CallManager IP"
incoming called-number .
dtmf-relay h245-alphanumeric
codec transparent
With this dial-peer I can connet directly to any ext , If I removed it I cannt call any ext from outside
that DP covers all the range, simply configure a dial-peers that covers ONLY DNs you want to reach, it's pretty obvious
java
java
Hi Javalenc
You meas thai for withc of 40 I want to be richt I will need a diferente DP?
Nothing to b done in CallManager ?
i really don't understand what you mean
richt/withc ????? what's that?
please rephrase on something that makes more sense
java
java
Hi Javalenc
Sorry for the wrong words
You means that for witch of 40 I want to be reach from outsid I will need a diferente DP?
Nothing to be done in CallManager ?
So you meant to ask, that for the 40 extensions, whether you needed a different Device pool. Correct?
Please rate useful posts.
witch ????? witch = bruja!
no, your question was how to block some phones from being called from outside
that needs 2 parts of config
1 VoIP dial-peer
1 GW in CUCM
GW includes an inbound CSS which defines what DNs you can reach.
it might be just better if you provide an example because you don't make any sense with that description
java
java
301 untill 310 don need to be reach from outside
311 untill 350 need to be reach
OK, 2 options
1 configure dial-peers to only match 311- 350
2 configure a dial-peer to match whole range but configure 301-310 in another partition which is not in the inbound CSS from GW
java
java
I try to manage the DDI with with translation rule on the GW , I create a voice transation rule and add a rule to the voice port , unfortunatly I can creta only 15 rule on the voice translation-rule
162
