Blocking specific incoming calls through CCM
I am using CCM 4.1
There are few incoming calls which I need to block using caller ID. I have the phone numbers.
Can I do it through Route Filters? Yes? How?
Gold
Re: Blocking specific incoming calls through CCM
On CM, calls cannot be blocked using Calling Number. You can only block based on the caled number. Incase you have a H323 Gateway, then calls can be blocked using the Calling Number
I see.
1. Would I have to block calls on voice gateway instead on CCM using calling number?
2. Just out of curiosity, how it could be done on H323 gateway?
Thanks.
Disregard my earlier message.
The gateways are MGCP gateway.
So is there a way that those phone calls could be blocked on MGCP G/W?
I found this link but guess this also applies to H323
http://www.cisco.com/en/US/customer/tech/tk652/tk90/technologies_configuration_example09186a00803f818a.shtml#con11
312
