Community Member
CAD goes from Ready state to Not Ready state for no reason
We are using IPCC Express.
Cisco Application Administration - 4.0(4)SR01_Build029
Package: IPCC Express Premium
Problem:
1) CAD goes from Ready state to Not Ready state for no reason. This is happening for only one particular agent.Not for all the agents.
2) Agent 'B' is facing a problem while she is logged in. Whenever she is on Ready Mode for 1 hour 30 mins, and even if she crosses this threshold by seconds Counter of the time becomes 0.
Need urgent help.
1 REPLY
Anonymous
N/A
Re: CAD goes from Ready state to Not Ready state for no reason
If an agent misses two consecutive routed calls, it will be forced to NOT READY state. There is another resaon. The Computer Telephony Integration (CTI) ports associated with the application do not have a calling search space (CSS) applied in the Cisco CallManager configuration that allows the CTI ports to transfer the call to the agents. In other words, the partition applied to the agent ICD directory number (DN) needs to be in the CSS applied to the CTI ports. If there is no CSS applied to the CTI ports, the transfers also fail. CTI ports must have a CSS configured.
110
