Call disconnect after 30 minutes
ergin.sezgin
We have cucm 8.0.3 and cisco router 2821 (c2800nm-advipservicesk9-mz.151-4.M.bin) , calls disconnect after 30 minutes via sip trunk.
Calls ;
İp phone (Skinny) > Cucm SIP Trunk > 2821 (NAT) > ISP
debug output from router
debug ip nat sip
Problem
001789: *Feb  2 09:00:53.208 UTC: NAT: SIP: [0] processing BYE message
001790: *Feb  2 09:00:53.208 UTC: NAT: SIP: [0] register:0 door_created:0
001791: *Feb  2 09:00:53.208 UTC: NAT: SIP: [0] translated embedded address CUCM IP->ISP NAT Global IP
001792: *Feb  2 09:00:53.208 UTC: NAT: SIP: [0] register:0 door_created:0
001793: *Feb  2 09:00:53.208 UTC: NAT: SIP: [0] translated embedded address :CUCM IP-> ISP NAT Global IP
Does anyone have idea about this issue?
Emmanuel Akum
Try changing the CUCM Service Parameter "SIP Session Expires Timer"  from the default (1800 secconds =30 mininutes) to a higher value; for example 14400 seconds (4 hours).
Pls give feedback afterwards (Let us konw If it helped).
Cheers
Emmanuel
5 Replies 5
Emmanuel Akum
Cheers
Emmanuel
Thank you for reply.
Hi Emmanuel,
I'd be curious to know if this is truly the resolution or a workaround.  It would seem that modifying the Session Expires timer in CUCM would only increase the time to 4 hours before the call dropped potentially?
Dalton W
Is this issue resolved, i am facing same issue. would like to know the resolution
sakoreabhijeet10,
The SIP session timer was the correct solution for that particular issue.
