call do not route to operator when users do not press any key
We have a new CUCM platform with Cisco Unity ver 9.1.2TT1.11900-2TT1.
We configured system handlers and and all "caller input" options runs good but when callers do not press any key the call goes to "nowhere", instead of going to Operator (default behavior).
Do you have any idea on what could be misconfigured here, or what should be configured to solve this problem??
Thanks a lot
Enrique
  • Unified Communications Applications
1 ACCEPTED SOLUTION
What's you after greeting
What's you after greeting action??
java
if this helps, please rate
www.cisco.com/go/pdi
java
Hi jaime, on my "Post
Hi jaime, on my "Post Greeting Recording" section we have the default:option
"Do not play Recording"
Thanks for your answer
Sorry for my last "wrong
Sorry for my last "wrong answer" .....You (again) was right, I had a bad configuration on "after greeting" setting..i had:
"Call Action: Take message".
I changed to " User with Mailbox pointing to recepcionist VM.
Jaime thanks a lot.
Enrique Villasana
24
