11-11-2013 05:39 PM - edited 03-19-2019 07:30 AM
Hi everybody
We recently migrated to call manager 8.6.2 and I want to know if it's possible forward secondary lines, because when we activate call forward only works in primary line.
I read this http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080916196.shtml , but I want to know if there an easy way which the final user can forward all his lines from the cisco phone.
Thanks.
Solved! Go to Solution.
11-11-2013 07:59 PM
Call forward all from the phone via the Call Forward All softkey for secondary lines does not work natively at all. There may be a 3rd party app or something along those lines but with the CUCM and phone itself, the answer is no.
Hailey
Please rate helpful posts!
11-11-2013 08:36 PM
You could look into this 3rd party product; IPPhone callForwarder.
Please refer the below link for more information
https://supportforums.cisco.com/thread/2224903
Sandesh Rao
11-11-2013 07:59 PM
Hailey
11-12-2013 08:40 AM
Thank you David, I appreciate your answer.
11-11-2013 08:36 PM
Sandesh Rao
11-12-2013 08:41 AM
Thanks Sandesh, I will check the 3rd party product
11-13-2013 07:28 AM
You can also give rights to access the ccmuser webpage. You can forward lines from there (if the cfa css is correct)
Gareth
12-19-2013 09:02 AM
So, Cisco takes the Attendant software away, and doesn't allow a PHYSICAL attendant device (a 7962 w/7915 for example) to actually perform attendant functions. That's F*#$&*%ng BRILLIANT.
