Call Forward to PSTN numbers not working
We have a CUCM version 8.6.  The call farward to internal extensions are working fine. But, to the PSTN numbers it is now working. We are able to call the PSTN numbers without any issue. Can somebody help us on this?
Rob Huffman
Hi Siva,
The most likely cause for this type of issue is the CSS that is applied @  the Call Forward All level on
the DN config page. Check out the CFWDALL CSS to make sure they are set with a level with
access to PSTN numbers
Cheers!
Rob
"Your life is worth much more than gold."
- Bob Marley
Rob Huffman
Hi Siva,
Cheers!
Rob
- Bob Marley
Thank you Bob.
