Call Forwarding issue in CUCM 7.1.3.
Hi I’m having problems with Call Forwarding. The scenario is below what I’m trying to achieve.
Call comes in to main DN number phone, if it is not answered after 3 rings it forwards to next number configured i.e. his 2nd line. If it does not answer within 3 rings the call goes back to the voicemail.
This is use to work in my old version of Call manager but couple of days back we have upgraded to 7.1.3 & the problem started.
Any help is most appreciated.
Re: Call Forwarding issue in CUCM 7.1.3.
So what behavior are you observing right now?
Is VM working fine if you press VM?
Does the N line you hunt has the forward to VM?
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
We are having issues right now & my VM is working fine. Actually if the line 1 is busy it should go to line 2 & if it is not answered it should reach to VM but the call is getting disconnecting before it reaches to line 2.
Srinivas.
Can you reach the voice mail from your second line?...check Calling Search Space.
Gabriel
Is this for all calls?
External and/or internal?
Have you tried doing a dummy change??
I mean remove the DNs from CF, save, insert the DNs in CF fields, save. Then test?
java
java
Sorry Guys,
I was sick & out of office still today. My issue is still pending & was escalated to Cisco TCA by Manager. I'll update the post once i find the answer. Once again thanks to everyone for all the suggestions.
Srinivas.
574
