01-23-2014 06:12 AM - edited 03-19-2019 07:47 AM
how do I configure call forwarding to mobile phone if the person did not answer the calls after 4 rings?
01-23-2014 06:17 AM
HI Yeow,
Is the phone registered to CUCM or CME ?
It is pretty simple for CUCM - set the call forward no answer setting on the Directory number page to the mobile number ( make sure to prefix 9 or any other prefix to match a Route pattern ) on CUCM.
For CME , you can use the call forward noan
You can find more details by searching on supportforums or google.
Manish
01-23-2014 06:39 AM
Alternatively to Manish's great answer (+5) you can invoke single number reach (mobile connect) feature if you are on a version that supports it.
HTH,
Chris
01-23-2014 07:55 AM
That's a nice alternative from Chris [+5].
Configuring SNR on CUCM
https://supportforums.cisco.com/docs/DOC-27111
Configuring SNR on CME
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmesnr.html
Manish
01-23-2014 05:35 PM
i have done the following on the CUCM, it still goes to voicemail if the call is not answered.
i m on version 9.1.2
01-23-2014 07:20 PM
Uncheck he Voicemail boxes in he picture. As long as the boxes are checked the desinaion number will be ignored and the forwarded call will always go o voicemail.
Manish
01-23-2014 08:21 PM
after I uncheck the voicemail option, it still does not goes to my mobile.
01-23-2014 08:26 PM
Are you rying to call from an external phone to trigger CFNA?
Is there a route pattern configured which starts with 99 or 9. , can you share the exact route pattern that you wish to use?
Manish
01-23-2014 08:31 PM
i managed to get it to work if I dial the full phone number.
if I dial internally, it does not work.
01-23-2014 08:42 PM
That's because you have left the 'Forward No Answer Internal' field blank, if you populate that one, even the internal calls would be forwarded.
Manish
01-23-2014 09:46 PM
it works perfectly now.
