Call Handler works w/internal calls not PSTN calls
j.magee
8 FXO ports for in and out bound traffic (H323 gateway setup) outbound works fine. Inbound traffic is pointed to a Call Handler (6600), , so what I did was create a 7910 set w/ the DN 6600 CFWAll to the Voice Mail pilot . Also a Call routing rule that points forwarded calls to this call handler. Internal calls to 6600 work fine. The call viewer shows dialed DN 6600, calling station 6608, and forwarding station 6600 (all is good) now the problem, External call just ring open, but you can see the calling information on the Call Viewer… What do you think is wrong …Thanks in Advance
voice-port 0/0:2
output attenuation 0
connection plar 6600
station-id number 5556600
caller-id enable
j.magee
The problem seems to be with the H323 setup , I changed config to MGCP and point the Attendant DN to the 7910 set all works fine ….Thanks
