07-15-2008 12:14 PM - edited 03-18-2019 09:18 PM
in the datasheet for CUC 2.1 it states that you can "Record a live conversation with a caller and have the recording sent to your mailbox".
Is there any system admin needed to enable this feature and as an end user how do you start recording a live conversation - I can't find this info in the documentation anywhere.
Chris
Solved! Go to Solution.
07-15-2008 12:41 PM
Chris, please the information contained at the following link:
http://www.ciscounitytools.com/HelpFiles/LiveRecord405/LiveRecordAppNote.htm
Setting up live record is the same for Unity Connection.
07-15-2008 12:41 PM
07-15-2008 11:53 PM
Could anyone tell me if there's a programable softkey, feature code, or a service which I could configure rather than have to press 'conf' then live record DN and then 'conf' again.
Chris
07-16-2008 05:55 AM
Hi Chris,
Great question! This question does come up from time to time, but sadly, due to the way Conferencing works there is no method to configure the setup with a single button yet.
The Live Record Softkey is now available on CME 4.3 so you have to figure that this will be available in CCM somewhere down the road :)
The only thing that can make the process any quicker is to configure a Speed Dial button for dialing the Live Record Pilot number.
From a subscriber phone, dial a called party
After the called party answers, press the Conference button on the phone,
****This is where the Speed Dial Button can be used**** and dial the Live Record Pilot number.
Press the Conference button again to join the Unity recorder into the conference.
Hope this helps!
Rob
07-16-2008 06:06 AM
Thanks Rob, thats very useful.
Chris
