call remain active on FXO port after call hangs up
I have an old analog pbx
I am installing a cucm 8.0
I am installing one voice gateway CME on cisco 1900 router with fxo card
Physical conexion
Analog phone - Old analog pbx  - fxo card on cisco 1900 CME - CUCM- switch cisco  -  IP phone
Communication between Old PBX and CUCM is working but I have a problem whend I hangs up
When  I made a call, it work,  then at  the  end of call I hangs up but I  observ that the calls remain active in the voice gateway
see below
Voice-GW#show voice call status
CallID     CID  ccVdb      Port        Slot/DSP:Ch  Called #   Codec    MLPP Dial-peers
0x6        11E7 0x29742C9C 0/2/0            No DSP *5000       None      500/0
0x14       11F8 0x29745FC8 0/2/2            No DSP *5000       None      500/0
0x1C       1203 0x2974762C 0/2/3            No DSP *5000       None      500/0
3 active calls found
Voice-GW#
Is it normal ?
Why the call remain active in voice call status after hangs up ?
How can I do to remove call on active call list after hangs up ?
Everyone's tags (6)
511
