07-27-2008 02:54 PM - edited 03-18-2019 09:23 PM
I ve a SIP trunk to CME.
When I call from CME to CM ,i can see "to called name";for example "to Ahmed"
BUT
the opposite not like that;i can see "to 1000"
NO name is displying even after call is estaplished.
I put the following parameters to allowed on SIP trunk on inbound & outbound calls:
Connected Line ID Presentation*
Connected Name Presentation*
I need to display on caller LCD screen "to called name"
07-27-2008 09:13 PM
yousseff,
The alerting name is a field that is local and used within the CCM, once you go out to a CME or intercluster, they aren't going to work. You need to setup directory services in CME using the 'directory entry' command on the side of the CME. It's a pain, but its the best I know how.
HTH, please rate useful posts.
Chad
07-29-2008 11:32 AM
Hi Chad,
But why it is working if i make a h323 trunk to CME through GK??
Actually I can't got yuor point regarding "directory entry" in CME.
Plz describe in more details.
Thx
