Calls from CCME to CM 4.2 droping exactly after 14 secs
when we are calling from call manager 4.2 to call manager express it is working fine. And if we are calling from call manager EXPRESS to call manager 4.2 , the call disconnects exactly on 14th second with cause code 41( temperory failure).
Both gateways are h323.
ccme 4.1 config:
dial-peer voice 7860 voip
destination-pattern 1...
session target ipv4:192.168.1.1
codec g711ulaw
telephony-service
no auto-reg-ephone
fxo hook-flash
load 7970 TERM70.7-0-3-0S
load 7911 SCCP11.7-2-1-0S
max-ephones 168
max-dn 300
ip source-address 10.12.0.1 port 2000
calling-number initiator
system message Cisco CME
cnf-file location flash:
time-zone 5
time-format 24
date-format dd-mm-yy
max-conferences 8 gain -6
call-forward pattern .T
call-forward system redirecting-expanded
moh music-on-hold.au
web admin system name cisco secret 5 $1$ZaoP$/dPHZyFPX/j3TXwv.2oEA/
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern 9.T
secondary-dialtone 9
create cnf-files version-stamp Jan 01 2002 00:00:00
CM 4.2:
cm 4.2 gateway
dial-peer voice 101 voip
description TO CM
session target ipv4:192.168.1.5
codec g711ulaw
Any suggestions will be higly appriciated.
Re: Calls from CCME to CM 4.2 droping exactly after 14 secs
In most cases there is some sort of TCP timer which is dropping the call.
Is there any link which can assist me then please forward me that
136
