Can CallManager 4.x connect to PBX [Siemens Hipath 4000] using SIP trunk?
Hi all,
I've Cisco CallManager 4.x and a PBX [Siemens Hipath 4000]. I saw that Hipath 4000 support SIP.
Can the CCM 4.x connect to Hipath4000 using SIP trunk? I can't find any documents about this scenario.
If not, please show me how to connect Hipath 4000 to Callmanager (hardware & software requirement for both PBX & CCM).
Green
Re: Can CallManager 4.x connect to PBX [Siemens Hipath 4000] usi
This is Unity forum, not CCM, please post it in IP telephony forum.
You might be able to to, just all depends on the SIP standard that Siemens uses and Cisco uses. Since SIP has a few standard features, either vendor may or may not have the same.
I would configure the SIP the trunk on CCM with the standards, and point the HiPath to it and cross your fingers.
You might be better off with going for a more standard T1 to T1 if all else fails.
Did you manage to complete this integration?
Silver
Did you get this to work ?
453
