CCM 5.1 and 2851 VG with 4 fxo
I am trying to configure MGCP so that I can use the fxo's on the VG to allow IP phone users access to long distance and on site extensions through CCM. This would be a 6 to get long distance and the extension to dial on site. I have configured the Gateway and added the fxo ports in Loop Start mode. What else do I need to do. I entered the MGCP, CCM-Manager and Config server commands on my VG. What else do I need to do? When I do a sh ccm-manager I get that the VG is still registering to the CCM. Any help would be great thank you.
Re: CCM 5.1 and 2851 VG with 4 fxo
Make sure you have service mgcpapp under the dial-peer and port configured as well on the router. The router if configured with a domain name (using command ip domain-name ABC.com) and the hostname of router is Router01. Then the MGCP gateway name inside Callmanager should be Router01.ABC.com. If there is no domain name configured in the router then your gateway name in CM should be Router01.
See if any of the above is true, if not revert back with your router config and a screen shot of your CM MGCP gateway configuration.
Sankar
PS: please remember to rate posts!@
I will try this now and reply with my finding s
Below are my configs of the VG. I plugged a phone line into port 0 and if I hit a 9 I get a dial tone but it wont dial anything after. busy after digits are dialed. Do I need to configure a destination-pattern on the dial-peer voice pots? Alos what do I need to do in CCM to allow for 5 digit inter-office dialing and long distance throught the PSTN. Users would dial a 9 to enter any of these two modes.
Here are my configs along with a sh ccm-manager
Current configuration : 3716 bytes
version 12.4
hostname FallonVG
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
resource policy
ip cef
ip domain name yourdomain.com
voice-card 0
no dspfarm
interface Loopback0
no ip address
shutdown
interface GigabitEthernet0/0
description "To Centroid Switch"
ip address 10.13.1.2 255.255.0.0
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
router ospf 100
no log-adjacency-changes
network 10.10.0.0 0.0.255.255 area 1
network 10.11.0.0 0.0.255.255 area 1
network 10.12.0.0 0.0.255.255 area 1
network 10.13.0.0 0.0.255.255 area 1
network 10.14.0.0 0.0.255.255 area 1
network 10.100.0.0 0.0.255.255 area 0
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
control-plane
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
ccm-manager switchback immediate
ccm-manager redundant-host 10.33.1.3
ccm-manager mgcp
ccm-manager config server 10.13.1.3
mgcp
mgcp call-agent 10.13.1.3 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode cisco
mgcp validate domain-name
mgcp profile default
dial-peer voice 100 pots
service mgcpapp
direct-inward-dial
port 0/0/0
dial-peer voice 101 pots
service mgcpapp
direct-inward-dial
port 0/0/1
dial-peer voice 102 pots
service mgcpapp
direct-inward-dial
port 0/0/2
dial-peer voice 103 pots
service mgcpapp
direct-inward-dial
port 0/0/3
line con 0
privilege level 15
login local
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet ssh
line vty 5 15
privilege level 15
login local
scheduler allocate 20000 1000
end
SH ccm-manager
FallonVG#sh ccm-manager
MGCP Domain Name: FallonVG.yourdomain.com
Priority Status Host
Primary Backup Ready 10.13.1.3
First Backup Registering with CM 10.33.1.3
Second Backup None
Current active Call Manager: None
Backhaul/Redundant link port: 2428
Failover Interval: 30 seconds
Keepalive Interval: 15 seconds
Last keepalive sent: 16:28:07 UTC Jun 8 2007 (elapsed time: 1w5d)
Last MGCP traffic time: 17:30:32 UTC Jun 20 2007 (elapsed time: 00:00:27)
Last failover time: 17:30:32 UTC Jun 20 2007 from (10.13.1.3)
Last switchback time: 17:30:02 UTC Jun 20 2007 from (10.33.1.3)
Switchback mode: Immediate
MGCP Fallback mode: Not Selected
Last MGCP Fallback start time: 17:16:18 UTC Jun 8 2007
Last MGCP Fallback end time: 15:54:03 UTC Jun 12 2007
MGCP Download Tones: Disabled
FAX mode: cisco
Configuration Error History:
353
