CCM 6.0 -- MobileConnect - H323 Gateway - FXO Port
Hi Guys:
My problem is the next one, my conf is CCM 6.0 -- MobileConnect - H323 Gateway - FXO Port.
I have configure the mobile connect part con the CCM6 to call a cellphone using a route patter pointing to an H323 Gateway (2821) this gateway has a FXO port.
The problem is that when i call the extension using the mobile connect profile, both the cellphone and ip phone ring but when i answer the call in the cellphone the call can not be established completly. again, both phones ring, i answer the call on the cellphone but the voice doesnt travel and the CCM 6 dont realize that i already answer the call on the cellphone.
When i call directly to the cellphone from any ip phone the call works just fine.
Before having CCM6 i used the CCM5.1 with the same above configuration and the external Mobility Manager, with CCM5.1 the cellphone call only was established when i answer the cellphone and TALK.
Re: CCM 6.0 -- MobileConnect - H323 Gateway - FXO Port
Can you please post you config from the router
I have a problem with mobile connect throuht FXO.
I am having the same problem with a customer's CUCMBE 6.1.2.1000-13. It works correctly on our internal system which is running the full version of CM 6.1.2.1000-13. Both systems are using MGCP. The only difference is the system that is working is a 2 server CM using PRI's and the system that is not working correctly uses CM Business Edition with FXO's. I will post if I find a fix.
The problem was that the cellphone call was being re-routed trou a system that was sending me an ack long before the call was answered.
VIP Super Bronze
Mobile Connect is not supported on FXO circuits.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucmbe/admin/6_0_1/ccmfeat/fsmobmgr.html#wp1125041
"Mobile Connect features are not supported for T1 CAS, FXO, FXS and BRI."
Please remember to rate helpful responses and identify helpful or
Bronze
guys
i know its not supported on FXO but just for basic testing in the lab, shouldnt the FXO still work?
ive just setup this and tried testing. it reaches my FXO port, and it tries to dial the cellular number but then disconnects.
again, i know it isnt supported but i was stil hoping i could have had this working for my internal Lab
When we tried it, the cell phone would ring but the talk path would not work. Then when the call disconnected, the FXO would not release the call. I had to manually shut and no shut the FXO port to get it working again. The Cisco doumentation also states that Mobile Connect does not work with FXO's.
Bronze
well to be honest im not getting the cell phone to even ring, just gets busy. my fxo port is accessed, the number of the cellular is correct but it then disconnects.
thanks for the reply though, i just wanted to setup as much features as possible in the lab and a PRI is NOT an option :)
normally, when its not supported it doesnt necessarily mean it wont work so i was hoping at least to get it working
I am having the same problem with H.323 GW and pri. It affects some users worse than others. Could it have something to do with a cell phone feature?
Guys,
They issue here is timing, I tried this setup several times with no hope, after debug and debug, hours and days, discovered that the issue here was timing, FXO it's not supported. Try with a BRI. Remenber one have the capacity to dial using en-bloc the other one not. Here is the big difference
219
