CCM 6 and OCS 2007 Connection
Hi all
I have CCM 6.0 and OCS 2007 Systems. Now, I want to connect these each other.
My Topo is : Cisco IPPhone ----CCM 6.0---GW 2811 ---Mediation Server----MOC.
In CCM 6, I created route pattern, H323 GW,...My router configuration is :
voice translation-rule 1
rule 1 // /+\1/
voice translation-rule 2
rule 1 /^\+200/ /200\1/
voice translation-profile pots
translate called 1
voice translation-profile voip
translate calling 2
dial-peer voice 100 voip
s
translation-profile outgoing pots
destination-pattern 200.
session protocol sipv2
session target ipv4:IP_MediationServer
session transport tcp
dtmf-relay rtp-nte sip-notify
codec g711ulaw
clid strip pi-restrict
no vad
dial-peer voice 102 voip
translation-profile outgoing voip
destination-pattern 51..
session target ipv4:IP_CCM6
codec g711ulaw
no vad
Cisco IP Phone can call to MOC. The call is OK.
When MOC call to Cisco IP Phone, The IP Phone is ring, I press answer button. But MOC is still calling status (ring out). The call is not established.
I don't know why.Anybody has an idea?
Re: CCM 6 and OCS 2007 Connection
I have not seen it setup this way. The only way I have seen this work is through Presence. Presence connects to OCS server (not Mediation server either!) The Mediation server is probably not ready to handle this type of call hand off to/from the cisco router and CUCM. Call Control will not be built into the SIP Trunks between OCS and Cisco until later this year.
For what you are trying to do, you may need to either try the following:
- Use Presence to connect to the OCS server (IM Client) I know this works because I have set it up with MOC-Presence-CUCM and make calls back and forth.
- You can look in this forum: http://forums.microsoft.com/TechNet/ShowForum.aspx?ForumID=845&SiteID=17
possibly a work around for what you are trying.
Typically, in Mediation servers, they are connected to with a SIP gateway (TIMG, Net.com, etc) These then have a Digital T1 trunk to another PBX. Mediation server hands the call off to the SIP gateway, it looks at it's rules, forwards the call to correct trunk (PBX). PBX then routes the call, call connect to station.
So PBX is CUCM. In the digital world of TDM, this will work fine. In the SIP world, i think you are pushing the evenlope to get this to work. Probably more towards the end of the year when MSFT and Cisco play nicer together. SIP version from MSFT is slightly different than the rest of the world.
Not sure if it's codecs either. With MSFT and their new "magic" codec, your call may be getting messed up between G711 and RTAudio. If you can force Mediation to use G711, maybe this will fix the problem.
Good luck! (not a fan of OCS mediation server can you tell???)
Thank you for replying .
Have you ever connected CCM 6 to OCS 2007 through CUPS 6.0?
Last week I use this Cisco Doc:http://cisco.com/en/US/docs/voice_ip_comm/cucme/pbx/interop/notes/617030nt.pdf to do that. But it is not success.
I Think this Document is not enough.
Could you give me more detail to this solution?
Thank
CUPS (Cisco Unified Presence Server) So yes, CUPS works with the MOC client and OCS 2007. The document does stink. There is another thread on here
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=Unified%20Communications%20Applications&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.1ddda965/21#selected_message
basically the same thing. (LCS is OCS 2007)
It all depends on what you are trying to do also. There also was a thread about 3845 routers. The 38 series has more SIP features I believe?
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.2cbf9214/0#selected_message
I tryed connecting OCS to CCM by using CUPS. Problem is same. MOC is still in "ring out" status when I press answer in Cisco IP Phone.
Please help me.
Hi. your design should work.
Tra to debug ccsip messages on the gateway to se if the correct sip messages are sent.
the gateway is a CUBE (IPIP GW) in your design.
you shold check the config giudes for this, and shoud make shure thet the CUBE is configured to translate between sip and h323.
this shoud look someting like this:
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
also check that your phones use G711 (not g729)
Hi all
I have configured successfully . My solution is Upgrading CCM 6.0 to CCM 6.1 .
Ahhh.. The 6.1 has some new SIP features that probably enabled this. Even from 5.0 to 6.0 SIP got better on the CUCM end.
thanks for the info!!
I have the same problem as you had but I already upgraded to CCM6.1.
Calls from CCM to OCS are OK
Calls from OCS to CCM are not ok. When MOC call to Cisco IP Phone, The IP Phone is ring, I press answer button. But MOC is still calling status (ring out). The call is not established.
could You give me the ios version of your gw ?
If you have any other advice, I'm interested.
thanx,
Bastien.
Hi Bastien
My IOS Router Version is Cisco IOS Software, 2800 Software (C2800NM-ADVENTERPRISEK9_IVS-M), Version 12.4(15)XY1, RELEASE SOFTWARE (fc1).
I think you must restart Router GW and CCM 6.1 after you finish configuring.
You also need check DNS confgiuration (CCM, OCS, Mediation Gateway..)
Good Luck.
Anyone get this fix? I have the same issue.
I had the same problem, but resolved it by configuring a sip to sip connection on the Cisco28xx.
Configure the following on the router
voice service voip
allow-connections sip to sip
sip
Then on the Mediation Server enter the IP of the Cisco Router and on the Cisco Router enter the IP of the Mediation Server within the dial-peer:
dial-peer voice 1 voip
description outbound to MEDIATION11
translation-profile outgoing TO-MEDIATION
preference 1
destination-pattern 777[0-6]
session target ipv4:IP_OF_MEDIATION
dtmf-relay sip-kpml
codec g711alaw
no vad
Peter
So did you you use a SIP trunk from CUCM or still H323?
You are right! I've forgotten to post, that I configured a SIP Trunk from CUCM to the Cisco Router. But the Cisco Router is still a H323 Gateway in the CUCM.
Hope this helps!
Thanks much for the config! We have been battling H323 to the 2800. Seems like there is a protocol issue between SIP and H323 at the router. The call leaves OCS, hits the Router, the Router sends the invite back, call hits h323, but it seems like it "doubles" the call legs and no reply is sent. But you can clearly see it in the RTMT logs on CUCM 6.1 the call is coming in on h323.
Good to know SIP trunks work then with the IPIP gateway.
Would version IOS are you on?
To clarify, the SIP trunk from CUCM is for outbound calls from IP phone to OCS via the gateway correct?
Are you still doing SIP to H323 at the dial peers at the router then?
cheers!
Yes, you are right, the SIP trunk is for the calls from Cisco IP-Phone to MOC. Currently I've got 2 systems running like this. The first is a Cisco1760 and for the callmanager this is a H323 Gateway as well, is connected to the PSTN and is running 12.4(15)T5. The second is a Cisco2811 running 12.4(15)T5 and this one I just use as a IPIP GW and digit manupulation(add, remove +).
Greetz
Have you check with MOC--->Mediation--->CUCM--->GW---->PSTN?
Or is the correct setup is MOC--->Mediation--->GW--->PSTN?
My goal is to get MOC to be able to dial out the Cisco gateway either directly or through the CUCM.
Im trying to figure out the best road to take. From it looks like, you have it all set correct?
Thanks much!!
Yes,I checked MOC to be able to dial out the Cisco gateway either directly or through the CUCM.
The both are OK.
In my company , Cisco IPT is main system. Every calls must through the CUCM. In there, We can manage Billing centrally. OCS has not to do that.
Do you have any OCS users that can make and receive calls from your CIsco gateway? I cant figure out for the life of how to get it to work.
cheers!
Have you resolved this issue?
I have some problems to dial out from MOC.
My design: MOC-->Mediation-->IPIP-GW-->CCM4.2-->H323 GW-->PSTN
The problem is, it rings at the destination in the PSTN, but when I pick up the phone, I still hear the ringback tone on MOC for some seconds and then I get a fast busy. The same happens with calls to Cisco IP Phones.
Any help is welcome.
469
