CCME/AIM-CUE - external calls to voicemail are not saved
we're having problems with our CCME/AIM-CUE setup. When external callers leave a message in the voicemail system these messages are not saved so the end-user never gets them Voicemails left from internal extensions or from other offices work fine.
Equipment used:
Cisco 2821 - IOS 12.4(15)T5 Adv. IP services
AIM-CUE : Unity Express 3.1.2
Attached are excerpts from the CCME and Unity configurations.
Any help would be much appreciated as I haven't been able to find out what is causing this problem.
kind regards,
Michel
Silver
Re: CCME/AIM-CUE - external calls to voicemail are not saved
Check your codec on the gateway's dial peer. You should specify the codec under the dial peer. If it doesn't show up in the config after you type it in, it was the default. If it does show up, then it wasn't the default and you have to save yourself at troubleshooting time. Always specify the codec on the router.
I've checked the codecs and specified new codecs on the external gateway dial-peer.
Unfortunately I still get the same problem. When calling in I'm asked to leave a message; I leave a message but the owner of the voicemail mailbox never recieves the message. He gets "no new messages" when checking his voicemail.
Here is the configuration of the voice codecs and dial-peers used for external calls and voicemail:
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
dial-peer voice 1 voip
translation-profile outgoing ReplaceCallingNumber
destination-pattern 0.T
rtp payload-type nte 102
voice-class codec 1
session protocol sipv2
session target ipv4:200.170.136.211
dtmf-relay rtp-nte
dial-peer voice 80100 voip
destination-pattern 801..
session target ipv4:172.21.68.2
dtmf-relay sip-notify
codec g711ulaw
no vad
149
