CCME Voicemail Problem
I have a user that when he tries to login to voicemail he is told the voicemail box is in use and he can't access it. We have CME 8.5
  • Unified Communications Applications
Everyone's tags (1)
And what are you using for VM????
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
What is the voicemail server you are using?. Is it Cisco Unity Express (CUE)?
If you are using CUE 8.x
Go to CUE admin GUI.
Voicemail -> Mailboxes
Select the mailbox which is locked, and click on unlock button.
or session into CUE from CLI, use "voicemail mailbox unlock owner" command to unlock the mailbox.
326
