Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
CCP IS NOT DISCOVERING DEVICE
Dear all,
     I could not Discover my cme router in CCP software.When I try to Discover It showing discovery Failed
Discovery details shows password error.But I can login to router using CLI,telnet and Via Web interface(GUI).
my configuration detailsa are
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip http path flash:/GUI
Could you Please help me
Thanks and Regards
Ajay Jose K
Hi.Which is the the error
Hi.
Which is the the error message you are receiving from CCP?
Let me know
Carlo
Please rate all helpful posts "The more you help the more you learn"
  Dear Carol,  Discovering
Dear Carol,
  Discovering details It showing Password error,But I can login to Gui mode using this same password
Ajay Jose K
HI Ajay.If you are using
HI Ajay.
If you are using simple password such as "cisco", try to change it with something more complex.
Let me know
Carlo
54
