Community Member
Changing Unity Call Routing Rules Order
Is there a faster way to change the order of the forwarding rules in Unity 4.2.1?
I have a large list of them and need to move the Default Call Handler to the bottom. This is going to take about an hour or more using SA.
Patrick
Re: Changing Unity Call Routing Rules Order
Nothing supported - there is a tech tool (not TAC supported) that you'll find under \commserver\techtools\ called "AvRulerEditor.exe" that will be quite a bit faster than the SA. Same basic idea, though - you have to move rules one at a time.
When you run it pick "routing" rules (there are no such things as rejection rules any longer) and use the move up and move down buttons to move your rules around then hit "ok" to save them.
Community Member
That worked perfectly. Thanks much.
I also used it to fix my Default Call Handler problem.
--Patrick
110
