cisco 7941 busy signal???
On cisco 7941 phone I want to achieve this:
When I use phone (calling) and if someone is trying to call me I would like that hi receives busy signal.
What i need to adjust??
THX,
Ivan
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Hi Ivan,
If you are using CUCM you would need to go to the DN config
page for your number and change the Busy Trigger to 1.
If you are using CME try "Huntstop Channel"
Cheers!
Rob
Hi Ivan,
Cheers!
Rob
Thank you Rob it works!
391
