You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
Cisco Calabrio Quality Management: 9.0.1.57 SR4 (OEM 8.8.1.57) - Recordings 15 Minute Playback Limit
We're having an issue where when we log into the QM website and click Recordings, and we click on a recording that has a Call Duration of longer than 15 minutes, it will cut off at the 15 minute mark. See below screenshot for an example (also attached):
Is this a setting that we can change? What is causing this limitation?
John
  • Unified Communications Applications
1 REPLY
Hey all,Turns out this is a
Hey all,
Turns out this is a bug in SR4, which requires the install of an Engineering Special (ES) patch. Calabrio support sent 9.0.1_SR4_ES7, which includes the fix for this problem, amongst others. I have attached the release notes of the patch so you may see the bug listed there.
Bug ID: QM-3516
Description: The system is stopping call recording when a call is over 15 minutes
Svc: Recording Process
John
426
