Cisco Mcs 7835i3 Hard disk lights not blinking
Hello All,
I have cisco MCS7835i3 with CUCM7.1 and two 72gb hard disks. Recently i am facing a issue LED's on hard drives are not blinking and CUCM gui is not accessible and all phone register to that cucm are down. Please help me in solving what should i do?
regrad,
Haseeb
  • Unified Communications Applications
VIP Purple
Hi Haseeb, are you able to
Hi Haseeb,
are you able to login through SSH into CUCM server?
if yes, u can run the command show hardware .if hard disk if faulty, you should find the output
Device Present
Virtual Drives    : 2
  Degraded        : 1
  Offline         : 0
Physical Devices  : 5
  Disks           : 4
  Critical Disks  : 2
  Failed Disks    : 1
Ideally, degraded and failed disk should be 0.
You can open the tac case with cisco so that they can open SR with IBM
regds,
aman
Dear Soi,Thanks for your kind
Dear Soi,
Thanks for your kind reply. Am not able to login in cucm through ssh and GUI also not accessible.
Regard,
haseeb
VIP Purple
Hi Haseeb, then, best is to
Hi Haseeb,
then, best is to open case with Cisco .Cisco would open SR with IBM for further troubleshooting.
regds,
aman
55
