Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Cisco Messaging Interface-Not Running
Hi All,
On the UCM 6.0 the Cisco Messaging Interface service is activated and when i check the status in 'control center feature services' it shows 'Not Running' and 'Activated'. If i start and refresh the page it again shows as 'Not Running'
Hall of Fame Super Red
Re: Cisco Messaging Interface-Not Running
Hi Vineet,
This interface is only used in CCM to Legacy VM integrations (via SMDI) if you are not setup that way this is why you are seeing this :)
Cisco Messaging Interface Service
The Cisco Messaging Interface allows you to connect a simplified message desk interface (SMDI)-compliant external **Third Party** voice-mail system with the Cisco CallManager. The CMI service provides the communication between the voice-mail system and Cisco CallManager. The SMDI defines a way for a phone system to provide a voice-mail system with the information needed to intelligently process incoming calls.
Genrally the Cisco Messaging Interface (CMI) is a Cisco CallManager service that should be run only on the publisher server. This service intercepts calls destined for voicemail and generates appropriate SMDI messages, which are then delivered to one of the server's Component Object Model (COM) ports.
From this doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a008037e2f3.html#wp1024396
Hope this helps!
Rob
Silver
Good Call Rob! I haven't been online. but this is exactly what that is.
Randy
All,
I understand what the CMI does and is for, but like the original post....  I cant get the CMI to start and run properly.  It keeps shutting back down and we are connecting a VM system via SMDI, so any thoughts as to why it wont let us keep it running.  Also, I was reading in a different post that CMI is typically activated on the Publisher server.....  we are doing it on the Subscriber due to location.  You have any forseen problems with that?  Thanks.
2987
