Cisco Mobile 8.0 - How many LICs per device?
Hi all,
The title says it all, I couldn't find at Cisco Docs how many device LICs I'm going to need for each Cisco Mobile 8.0 client device?
Does anyone knows how many LICs are going to be needed per device?
Thanks in advice.
Guilherme
1 ACCEPTED SOLUTION
Re: Cisco Mobile 8.0 - How many LICs per device?
4 DLU as standalone device, 1 DLU if adjunct device
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
java
java
Thanks!
217
