03-02-2012 02:27 AM - edited 03-19-2019 04:30 AM
I am configuring a CUE 8.6 module and noticed that my administration page says:
Cisco Survivable Remote Site Voicemail - Administration
What is this? I thouight I was configuring a normal CUE.
Also some of the licenses start with: SRSV-
I want to install licenses for 50 mailboxes, but I am not sure about what I now have!
The CUE has its CTI and Call-in numbers correctly registered on callmanager (7.1.5)
Anyone can tell me what "Cisco Survivable Remote Site Voicemail" is and if this correct to work with callmanager.
It seesm like SRST for voice mail.
JH
Solved! Go to Solution.
03-02-2012 04:13 AM
Yes SRSV is like SRST for voice mail. When a remote site does not have access to your central voicemail system, this module will take care of VM functionality
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6789/ps5745/ps10769/data_sheet_c78-600182.html
Ronak Patel
03-02-2012 05:14 AM
Hi Jan,
Sadly, you will need to start over. There are some excellent answers in this recent thread
https://supportforums.cisco.com/message/3533754#3533754
Cheers!
Rob
03-02-2012 04:13 AM
Ronak Patel
03-02-2012 04:23 AM
Hello Ronak,
Thanks for your quick response.
The issue is that I don't want this, we wanted a normal CUE.
I checked the BOM and we ordered:
ISM-SRE-300-K9
SCUE-ISM-8.5-K9
And after some more searching on Cisco web site its seems that:
SCUE-ISM-8.5-K9 is the normal CUE and SCUE-SV-ISM-85-K9 is the SRSV image.
Seems somthing went wrong.
Can I use the SRSV image with callmanager, or do I have to start from scratch and load the normal image?
Thank you,
JH
03-02-2012 05:14 AM
Hi Jan,
Cheers!
Rob
03-02-2012 05:22 AM
Hi Rob,
Thank you for the link.
Seems we have to start from scratch.
Jan
