Silver
Cisco Survivable Remote Site Voicemail - Administration ????
I am configuring a CUE 8.6 module and noticed that my administration page says:
What is this? I thouight I was configuring a normal CUE.
Also some of the licenses start with: SRSV-
I want to install licenses for 50 mailboxes, but I am not sure about what I now have!
The CUE has its CTI and Call-in numbers correctly registered on callmanager (7.1.5)
Anyone can tell me what "Cisco Survivable Remote Site Voicemail" is and if this correct to work with callmanager.
It seesm like SRST for voice mail.
JH
Everyone's tags (1)
2 ACCEPTED SOLUTIONS
Blue
Yes SRSV is like SRST for voice mail. When a remote site does not have access to your central voicemail system, this module will take care of VM functionality
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6789/ps5745/ps10769/data_sheet_c78-600182.html
Ronak Patel
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Hall of Fame Super Red
Re: Cisco Survivable Remote Site Voicemail - Administration ???
Hi Jan,
Sadly, you will need to start over. There are some excellent answers in this recent thread
https://supportforums.cisco.com/message/3533754#3533754
Cheers!
Rob
Blue
Ronak Patel
Silver
Hello Ronak,
Thanks for your quick response.
The issue is that I don't want this, we wanted a normal CUE.
I checked the BOM and we ordered:
ISM-SRE-300-K9
SCUE-ISM-8.5-K9
And after some more searching on Cisco web site its seems that:
SCUE-ISM-8.5-K9 is the normal CUE and SCUE-SV-ISM-85-K9 is the SRSV image.
Seems somthing went wrong.
Can I use the SRSV image with callmanager, or do I have to start from scratch and load the normal image?
Thank you,
JH
Hi Jan,
Cheers!
Rob
Silver
Hi Rob,
Thank you for the link.
Seems we have to start from scratch.
Jan
513
