Cisco Unity Connection - Assigning 2 recordings to one System Call Handler
Hi All,
We have got a request from a client regarding the below:
During week days (Mon - Fri) from 7pm to 7am, a recording informing that office is closed should be played when incoming call reach extension 1234.
During week end (Fri 7pm - Mon 7am), another recording should be played informing when an incoming call to 1234 is done.
Unfortunately, it seems that only one recording under the Closed greeting can be configured for one active schedule.
Is there any solution to configure same on CUC?
Thanks and Best Regards,
Pascal
Everyone's tags (4)
1 ACCEPTED SOLUTION
VIP Gold
For this you can configure
For this you can configure "Time of Day" call routing in CUCM with one more system call handler in CUC, it will work perfectly.
Suresh
VIP Gold
Suresh
Dear All,Thank you for your
Dear All,
Thank you for your response.
Time of Day Routing was used in order to setup 2 greetings.
Do note that 2 Translation pattern was used in this setup as well as 2 SCH.
Alternate greetings was used as well instead of closed greetings.
Important point is that scheduling is completely done CUCM, not on CUC.
Have a nice day everyone.
Kind Regards,
Pascal
Bronze
it can be done in unity
it can be done in unity connection with different schedule settings for each call handler
example:
main greeting with normal business hour ==> weekday close hour greeting ==> weekend close hour greeting
set up 3 different schedule and 3 call handlers to accomplish this task.
DP
Dear all, I want so do
Dear all, I want so do something similar to this.
- Between 8 am and 6 pm when everybody is busy "Greeting Busy"
- Between 6 pm and 8 am when nobody is at the office "Greeting closed"
How do I handle this? I can create a schedule with the two time ranges but I am missing the connection between the schedules and the greetings. Who can help me?
96
