Community Member
Click2Call widget - call from hyperlinks
Hi NetPro´s,
I´m actually facing a issue with the Click to Call plugin, which should be used to dial telephone numbers from a CRM system..
When using two different types of hyperlinks (within Internet Explorer) we have a different behaviour, see:
Doesn´t work:
<a title="Click to Dial">+44333444555</a>
Works:
<a href="/001A000000MWuF8IAL">+44333444555</a>
How is the plugin working and is there a option to manipulate the behaviour of the hyperlinks.. or maybe a option to make a hyperlink so that when you click it, it automatically dials out, using the C2C plugin.
Any ideas are welcome..
Cheers
Torsten.
PS: Hyperlink Test:
+44111222333
508
