Community Member
CME - Busy lamp field for a phone rather than a line
I need a config on CME that will provide a busy lamp field if any line on a phone is busy on a multi-line phone i.e. the phone is busy.
The customer is using 7931 phones and uses the first 8 line buttons. The first for their DDI and another 7 or so for shared DDI lines.
They want to use the remaining buttons as BLF. The problem is I can only configure a BLF to monitor another line rather than for the phone itself. I have come across other PBX's which can do this.
Does anyone have an idea how this requirement could be achieved?
Re: CME - Busy lamp field for a phone rather than a line
I think as of now Busy lamp is based on the phone only. To enable Busy Lamp Field (BLF) monitoring for a speed-dial number on a phone registered to Cisco Unified CME, use the blf-speed-dial command in ephone or voice register pool configuration mode. To disable BLF monitoring for speed-dial, use the no form of this command.
Community Member
I logged a Cisco TAC Case, details below.
Problem Description:
You would like to configure the BLF in such a way that it is on when any line on the watched SCCP phone is busy - i.e. when the phone itself is busy.
Action plan:
If the problem description is correct, you can configure this behaviour using 'w' separator in the button assignment. For example, in this
Ephone 1
button 1:3 2:4
Ephone 2
button 1w3
The button 1 on ephone 2 will indicate 'busy' if any line on ephone 1 is busy (1w3 means: configure button 1 as BLF for the phone that the primary extension is ephone-dn 3). This feature is available in the CME version you are running.
For further description, please have a look at this link:
